ChuckD
Ok I am just wrapping my brain aroung the EQ section of the Neve 1081. Can some explain it to me in greater detail?
From the ten81 project I have the BOM which lists the following:
SW2 Trebble 3 Pole x 6 Position Rotary Shorting
SW3 Hi-Mid 1 Pole x 11 Position Rotary Non-Shorting
SW6 Lo-Mid 1 Pole x 11 Position Rotary Non-Shorting
SW8 Bass 3 Pole x 6 Position Rotary Non-Shorting
SW9 Hi Filter 3 Pole x 6 Position Rotary Non-Shorting
SW9 Lo Filter 3 Pole x 6 Position Rotary Non-Shorting
Output Fader 10K Log Pot
SW1 Shelving SPDT
SW4 HI-Q SPDT
SW5 HI-Q SPDT
The Neve sites list this:
HF peak / dip or shelving switch
HF at: 15, 10, 6.8, 4.7, 3.3kHz and off
HMF at: 8.2, 5.6, 4.7, 3.9, 3.3, 2.7, 2.2, 1.8, 1.5kHz and off
HMF bandwidth switch
LMF bandwidth switch
LMF at: 1200, 1000, 820, 680, 560, 470, 390, 330, 270, 220Hz and off
LF peak / dip or shelving switch
LF at: 300, 180, 100, 56, 33 and off
HPF: 27, 47, 82, 150, 270 Hz and off
LPF: 15k, 12k, 8.7k, 5.6k, 3.9kHz and off
1. These don't seem to match up on the last two switches, as the orignal had a 2-in-one rotary didn't it?
2. And why do we need 3 Pole swicthes for the 6 Position ones?
Can someone shed some light on this for me? Thanks! I don't own one of these and have never used an orginal 1081.
Parts info: I have found Electroswitch carries the following:
E5G0323N 3pole 23positions shaft_lenght=1/2" or 2/8"
D1G0312N 3pole 12postions Non-short
D1G0312S 3pole 12postions Short
Anyone else find these somewhere that is "in-stock"?
-ChuckD
SW1 Shelving SPDT
SW4 HI-Q SPDT
SW5 HI-Q SPDT
-ChuckD
