G gtrmac Well-known member Joined Dec 22, 2004 Messages 46 Nov 30, 2005 #1 Can anyone tell me who the manufacturer is of the type of terminal blocks like those used on the JLM power supplies? I want to use them on some stuff I'm making and I need the footprints.
Greg Well-known member Joined Jun 7, 2004 Messages 1,784 Location New Orleans, LA Dec 1, 2005 #2 I'm looking at the 2-pin and it reads: DINKLE DT 126 V Hope that helps some.
G Guest Guest Dec 1, 2005 #3 I just used bog std ones I had lying around... JPR Catalogue Terminal Blocks But ... the real estate is a bit limited on the powerstation (the x5one) So if like me your blocks where too big depthwise - just mount the rsistors and caps underneath the board (thats what I did)
G gtrmac Well-known member Joined Dec 22, 2004 Messages 46 Dec 1, 2005 #4 Thanks guys. The JPR Catalogue items look like the exact match.
G Guest Guest Dec 2, 2005 #5 You can get those terminal blocks absolutely everywhere The thing to check is the spacing - the spacings seems to be all over the place though
