LG
Member
Hi folks,
I've been trying to learn to use eagle cad, running the free version with limited board size. Could some of you kind people answer some questions?
Since the limited board size I've decided to do a double side layout. Im running power lines on one side and the rest on the other.
Is it ok to run a ground plane on both sides on a double sided pcb for filling it up? than i wont be etching away a lot at copper. Are there any reasons for keeping the ground plane on only on one side?
If i'll go on and add a ground plane on both sides, how many vias should i use for connecting them to gather?
Or is this total bullshit? I guess i could route the power lines on the bottom as well with extended use of jumpers.....
The schematic is from the from the data sheets +2 relays for pad + polarity. I intent to change those connectors to one 8 pin molex later and make a pcb layout for the switches and gain pot as well.
Hope someone has the patience to help a newbie
all the best, Leifur
