THAT1512 / Transformer 'blind test' mic preamp
jamesk
New member
United Kingdom
This is my first proper post here, after my post in the introduction section.
I am working on two mic preamp designs. One uses a transformer input and NE5534 gain stage, the other uses a THAT1512 IC. Both versions use Douglas Self's Quasi-floating balanced output. The preamps have identical controls, with +48V and -20dB pad switches and a stepped 12-way gain switch. The aim of the build is to create two preamps that look the same externally but have completely different topologies, and then perform blind tests on various sources to see if people have a preference for one or the other.
Here is the schematic for the transformer version:
and the THAT1512 version:
This is the gain switch for the transformer version. The THAT1512 version uses the same PCB but with different resistor values to give the same gain.
This is the PSU:
The first issue I am having is understanding the behaviour of the output stage properly. When testing, I can adjust the balance between the hot and cold outputs to be equal at 1kHz, but when I increase the frequency, they go out of balance. I also simulated the circuit in LTSpice and observed the same behaviour. Can anyone explain the reason behind this and what the best approach to balancing the output levels is. It seems like a significant flaw of the design but since it has been used in commercial products, I assume I'm missing something!
Here is the output at 1kHz:
And at 30kHz:
Thanks in advance!
James
Not sure of the exact reason for the imbalance, but that circuit was designed for audio frequency (20Hz-20kHz), so I don’t think balance at 30kHz (or anything above 20kHz) was a design goal.
Thanks for the response. I should have said, I've shown it at 30kHz as it's very exaggerated and visible. The imbalance becomes obvious above 10kHz.
Another thing I don't understand is how the circuit is unbalanced in the SPICE simulation when the pot is set exactly half-way. My understanding was that it's there to adjust for tolerances in the resistors, but in the simulation, the resistors are all exact values.
I feel like I'm missing something really fundamental here.
Here it is at 1kHz.
James
A balanced signal exists only between the hot and cold terminals. The third terminal is a screen not a ground. The two voltages relative to "ground" do not have to be equal. It is the impedances that are balanced not the signals.
I also notice in the first schematic you have a pot with the wiper to the NE5534 -ve input, one end connected the the NE5534 output and the last one to ground via a capacitor. To ensure a fixed, known maximum gain is available you should include a resistor in series with the capacitor (But now I have just seen your gain switch schematic so I see you are already aware of this :))
