THAT1512 / Transformer 'blind test' mic preamp
jamesk
Member
United Kingdom
This is my first proper post here, after my post in the introduction section.
I am working on two mic preamp designs. One uses a transformer input and NE5534 gain stage, the other uses a THAT1512 IC. Both versions use Douglas Self's Quasi-floating balanced output. The preamps have identical controls, with +48V and -20dB pad switches and a stepped 12-way gain switch. The aim of the build is to create two preamps that look the same externally but have completely different topologies, and then perform blind tests on various sources to see if people have a preference for one or the other.
Here is the schematic for the transformer version:
and the THAT1512 version:
This is the gain switch for the transformer version. The THAT1512 version uses the same PCB but with different resistor values to give the same gain.
This is the PSU:
The first issue I am having is understanding the behaviour of the output stage properly. When testing, I can adjust the balance between the hot and cold outputs to be equal at 1kHz, but when I increase the frequency, they go out of balance. I also simulated the circuit in LTSpice and observed the same behaviour. Can anyone explain the reason behind this and what the best approach to balancing the output levels is. It seems like a significant flaw of the design but since it has been used in commercial products, I assume I'm missing something!
Here is the output at 1kHz:
And at 30kHz:
Thanks in advance!
James
Not sure of the exact reason for the imbalance, but that circuit was designed for audio frequency (20Hz-20kHz), so I don’t think balance at 30kHz (or anything above 20kHz) was a design goal.
Thanks for the response. I should have said, I've shown it at 30kHz as it's very exaggerated and visible. The imbalance becomes obvious above 10kHz.
Another thing I don't understand is how the circuit is unbalanced in the SPICE simulation when the pot is set exactly half-way. My understanding was that it's there to adjust for tolerances in the resistors, but in the simulation, the resistors are all exact values.
I feel like I'm missing something really fundamental here.
Here it is at 1kHz.
James
A balanced signal exists only between the hot and cold terminals. The third terminal is a screen not a ground. The two voltages relative to "ground" do not have to be equal. It is the impedances that are balanced not the signals.
I also notice in the first schematic you have a pot with the wiper to the NE5534 -ve input, one end connected the the NE5534 output and the last one to ground via a capacitor. To ensure a fixed, known maximum gain is available you should include a resistor in series with the capacitor (But now I have just seen your gain switch schematic so I see you are already aware of this :))
Why not use a THAT 1646 for the balanced output?
Good question. I did consider this, but my long-term goal is to build a mixing desk so using 1646s on all the outputs would be prohibitively expensive. I realise this is a far-off goal, but I want to build up the various circuit building blocks bit by bit, so one of the requirements is that it doesn't become stupidly expensive on a large scale.
I see, but you're probably not saving as much as you think. If R18 is a good quality multiturn trim pot (which it should be) it's going to cost over half of the 1646's cost by itself. I was also initially put off by the cost, but finally started using these on all my preamp outputs and never looked back. They just work great.
+1
THAT 1646 needs few peripheral components, which not only translates into faster matching-free stuffing time but also less real estate on PCBs. And they are extremely well matched btw channels with worst case ~0.1 dB. Plus they get cheaper (in mid run) when you aim for a price break up front.
A classic alternative would be INA.
Thanks for this suggestion. Looking at the prices, the THAT1646 does seem too expensive, especially since I would need close to 100 outputs on a desk.
The DRV135, though, is substantially cheaper. I've calculated the cost per unit on a run of 100 for the quasi-floating output and the DRV135 and they are £1.87 and £2.68, respectively. That translates into £81 more for the whole desk, which isn't very much given the probable total build cost.
Combined with not having to manually balance each output, this doesn't seem too bad.
Is the DRV135 likely to be as low noise as the NE5532 version, though?
@ruffrecords, thanks. I've measured the differential output voltage using the subtract function on my oscilloscope now. There is still a small increase in output at high frequencies, but this is much less pronounced than the change in the balance, so the situation doesn't seem so bad. My concern with the signals becoming unbalanced is that it will result in lower headroom as one clips earlier than the other.
James
@jamesk what about this?
https://www.jensen-transformers.com/wp-content/uploads/2014/08/an003.pdf
You should read the whole paper, but pay special attention to Section 2.4, "A simple alternative".
Of course a DRV134 is cheap, but maybe for 100 outputs (as you mentioned) an unballanced 5532 driver plus this impedance-ballancing arrangement would suffice.
Please note that even Jensen - *very* interested in selling you a transformer or two - is saying, on an official Applicatin Note of theirs, that (and I quote):
"A simple modification to equipment with unbalanced outputs can convert it to have true balanced outputs"
The emphasis is Jensen's, not mine!
A 5532 plus a couple of resistors and maybe a capacitor truly would be cheaper and work as well. Lots and lots of "prosumer" (and some pro) gear have ballanced outputs that way.
There is some mixup in "balanced" signalling, which may have an out of phase signal on "the other" lead, or not.
It being used just for DC power.
Ethernet, LVDS and others are called "differential", easy to do with a transformer.
True differential reduces common mode interference, which is a good thing.
I thought about the DRV135 after I posted and meant to come back and mention it as a cheaper alternative, but I see you found it. I've never used one but the noise spec is -98dB (THAT is -101dB), plenty good if you ask me.
Why a second gain stage after the 1512?
Because I wanted more total gain than what the 1512 can do alone. Also, I don't want the 1512 to be taxed so much by being asked to do alot. And I also wanted to take advantage of the 1512's unique ability to do -6dB so it could behave as a pad for higher level signals. The second stage is doing all the work, the 1512 is more playing the role of an input transformer.
And finally, using a discrete opamp for the main gain stage allows me to play with color in a way that a 1512 alone couldn't.
I have looked at impedance balancing, too. The reason I think I'm going to go for active balanced outputs is that it enables internal -2dBu operation to be doubled to +4dBu at the output without any loss of headroom. How necessary this is, though, I'm not sure. I'm happy to be convinced otherwise.
This may be what I end up going for. From looking at the datasheet, the output can be directly coupled to the output XLR with no blocking capacitors. Is that correct?
I've finished assembling the boards now so here are the IC and transformer versions next to eachother. The white wires are just for testing purposed.
The gain switch has a small round PCB mounted to the back so that it can be connected with only 2/3 wires.
I've soldered everything to the PSU board apart from the regulators and rectifier. This is because they're going to be mounted to the case and I need to get them to line up properly first.
I realise that I've made a mistake on the IC board and connected the input RF filter to signal ground. I can remove those capacitors from the board and wire it to chassis ground, directly on the input XLR instead. Is that correct?
James
