kazper
Seriously check out the emachineshop software and program.
I'm going to use them for my upcoming 51X stuff sled.
owel said:I use 0.25" standoffs too.
A very small tolerance for manufactured products like we are talking about with mating connectors and so on....Let's convert 0.019" to Metric... = 0.48mm. Less than half a millimeter.
This is a bit disturbing to find this out.
jsteiger said:Yes Mike, the 51x rack is designed at 7/16" from PCB center to center of module. Cemal worked from the spec sheet and an API 6 space rack from Volker. Now, that distance can vary slightly due to screw holes and where the card edge connectors get soldered to the PCB.
This is just a tolerance I think.
Look at the 1.75" rack space and how many different sizes people make their front panels and cases. It is a standard but is varied from all the time.
I will take a pic of a 550b module later today. It is their standard and you will see how far off it is!
ruckus328 said:Not trying to be a jerk but I don't know where you're getting your info.
Crusty2 said:Standard PEMs are shorter than an equivalent standoff, so you would get your error back (and then some): http://www.pemnet.com/fastening_products/pdf/sodata.pdf
Lately I've been wondering why aluminum? Steel is much better for shielding, yes?
