Hi.
First of all, apologies for not replying sooner, the weekend was a bit hectic.
Good point, I did not consider that. I am gonna be using zinc plate steel for the chassis body so will point this out to the fabricator.
That unfortunate feature of all ferrous materials doesn't always play a significant role, but when it does, it can be a real PITA.
And if the holes are small enough, it may even require the holes to be drilled or punched instead, rather than laser cut, pumping the price of manufacturing up considerably.
Totally get the other points you made, thanks a lot for your valued contributions.
You're welcome.
The working force is listed as 250kg.
That's way less than what I expected, but OTOH would explain the punching capacity figures the seller gave to You.
As nice as it sounded, I do agree that unfortunately it's not necessarily the right press for Your needs.
Unless I am missing something ?
No You're not.
That said, while I don't have any experience with the fasteners You're using and obviously do not doubt the manufacturers recommendation, the 11/15kN installation force requirement sounds very high for such a small material displacement.
I also mainly use manual arbor press or hand cranked hydraulic shop press for such jobs so it's somewhat hard to determine what the actual force required for each job is.
"If it doesn't come out or doesn't go in willingly, use a longer lever and try again"
If the height ajustable head isn't absolutely necessary, a fixed C-frame arbor press converted to pneumatic or hydraulic operation might be the most economical solution for Your needs.
Or even a small hydraulic shop press if You have the room for the bigger footprint.
Regards,
Sam
