pucho812
I intend a few eq and routing, but was just thinking of layout and haveint the mic pres in the center. then again why reinvent the wheel? so who knows.Full EQ and routing on every input is the Classic mixer way of doing things. I suspect mic pres with just HPF is all that is normally necessary. If the odd track does need to be EQ's in record then the easiest way is to include an insert on the mic pre output. To mix just one or two 'groups' of inputs to a trackj on record could be done with a couple of AUXes.
