The official G9 help thread
Thanks from here too - I've been looking for this type for a long time..
You would think that hookup wire would be among the easiest things to source - but I find the exact opposite irl...
Jakob E.
Found out the cable I got is this type you were discussing in an old thread back then. Pre bond.
It was screaming quality from distance.
Super excited I found out how it's called.
Talking about wiring from PT & filter caps to PCB, what option should be the best?
Western union splice/double heat shrink tag strip, terminal/screw block, wirenuts or other?
Knowing that :
• My PT's leads are common copper stranded for HV (PVC ins.) & "two strand" twisted solid (fiber kind of ins.) for 15V windings
• I'll use that quality pre bond double ins 22 awg wire
• Don't own a proper ferrule crimping tool & never liked the idea.
Old good 60/40 Fluitin & Magnastat lover.
The wires will be soldered straight to PCB. I'll remove the PCB terminal blocks I had used when I first built it back then.
Pros/cons
• was about to use western union splice but then I realized PT leads are stranded & two twisted solids.
• tag strip/eyelet/turret is what I'm using right now but the tag strip board I'd used was sourced from eBay (those cheapo yellow phenolic ones) & noticed tarnishing on eyelets.
It's pretty hard to source new quality ones here. More easy to find "true" old eyelets etc in fleas / e-waste but I'll have to be patient.
• EU terminal block. If pre bond wires can safely go in there (screw connection) & ferrules are not necessarily needed then I'll go for it.
I've been reading on this since two days. Unable to make a clear decision. Hopefully I'm not planning to open G9 again for a long time so I want to be sure.
Any ideas?
Hello, I have a problem on the power supply on the G9 .
I'm using a 2*15 first and a 2*12v for the second transformer.
I have 275vac on the out put .
I have 360vDC instead of 245v on HT .
No valve on the board ...
I think that my 783 is dead because of a too high input .
I think i should change the second transformer by a 2*15v . And change the 783 . The caps are 400v so they must be ok.
Do you think i'm right ?
Thanks a lot
Hi Pitt,
Yes, 360V DC is too high - and yup, probably best to use a 2x15 for the second transformer in this case. That said, this should be measured under load, i.e. with tubes heated up and drawing their realistic current.
The TL783 is protected from death by high voltages by the string of 39V zeners and the 1N4007 in reverse (check that you have gotten these right) - I have ever only seen broken TL783's from shorting accidents - and I use a lot of them for similar high voltages
/Jakob E.
No it was without load.
In fact, i read that the max voltage for ecc82 is 360V ... So i don't want to take the risk of killing my tubes.
I will try to invert the two transformers 😉.
..as soon as the tubes begin to draw current, the voltage decreases a lot. Don't worry about overvoltage while waiting for tube heater to come on, tubes are tough (at least I never mucked up a tube by doing this)
IOW, your psu may be just fine already...
I know I've disrupted the very essence of this fully analog design, but what can I say? Old habits die hard. If you don't banish me to the archives, maybe what I've just finished might interest you. Since I knew nothing about preamps, I spent the first year studying all the most renowned schematics. After selecting the G9 as my starting point, I dedicated another year to analyzing it piece by piece, creating submodules to measure everything I could, and understanding the logic behind it all.
A little side note: I'm an amateur musician and an electronics engineer with 30 years of experience, specializing in high-frequency systems. Anyway, I then spent six months designing the circuit and another six months assembling, programming, and testing it. All in all, it took me around four years to create this.
View attachment pop.mp4
It's a dual G9, meaning a dual mono or stereo version, controlled by an open-source ATmega/Arduino microcontroller.
Power supply
There are some rather crude additions, but they are the result of extensive research and experimentation. The switching power supplies may have shocked you, but after countless tests, it was difficult to integrate a regulated power supply without facing EMC issues, overheating, or space constraints. These power supplies are well-filtered (I spent a long time searching for these models and tested a lot of gear that ended up in the trash). I also monitor the power supply temperatures and can certify that all components can operate up to around 60°C ambient.
I also spent a lot of time studying the current draw cycles and refining the NTC circuits and consumption setups to avoid putting too much strain on the power supplies at startup. I’m very satisfied with the results of this work.
Parallèle Drive
Of course, you've probably noticed the six tubes, which also required some power. That's because I added two parallel channels without dry/wet blending — you'll see what I mean. These channels use ECC83 tubes in a typical British setup from the 70s/80s, allowing me to add a bit of grit to the upper mids of vocals or wind instruments.
G9 channel
Since I have extensive experience in EMC, I also explored the possibility of opening the feedback loop. I tested many different tubes, and I can confirm that even with the high gain of ECC83 tubes, I can open the G9's feedback loop without any issues using relays. It was a bold move initially, but the stability is solid, delivering a punch of around +11 to +12 dB on this channel.
Level setting
Each tube is driven differently on each channel. The clean channel is controlled via the cathode, like in the original schematic, using digital potentiometers. The drive channel is controlled by its attack, which is more conventional. The output tube, an ECC82, is also driven via its grid through an impressive PGA circuit from Texas Instruments. This circuit also manages the insert input level for each channel (though I admit I've encountered some circuit issues here, and it doesn't work exactly as I want).
HPF:
I almost forgot, I added a real bypass with a relay (there are 32 relays on the board) going to a HPF (High-Pass Filter). You select the cutoff frequency, and voilà...
Noise & zero crossing
Of course, I had to address the noise issues with the potentiometers. I initially designed a homemade zero-crossing circuit, but I wasn't convinced by the results. In the end, on the CLEAN channel, since it's controlled via the cathode circuit, it's completely transparent. No issues on the output circuit either, as the Texas Instruments chip handles it smoothly, even at high gain. For the drive channel, my solution was less than ideal; since the PCB was already made, I couldn't change it. If I were to create another version, I would definitely use the Texas Instruments chip without hesitation.
PCB & control
Le PCB est une conception à 4 couches, avec la section numérique en dessous et la section analogique au-dessus. Les alimentations électriques sont sur la couche 3, tandis que la couche 2 est un plan en cuivre massif pour éviter les interférences. Il y a environ 1 000 composants. L'ensemble du système peut être contrôlé soit via des boutons, pour ceux qui connaissent les versions analogiques traditionnelles, soit via l'écran tactile, voire via un VST intégré à votre DAW - parfait pour les débutants.
Mecanic:
Mechanically, there's nothing particularly special, it's just tight, that's all. I made the front panels myself over time, I have a small machining center for that.
Input selection:
For each channel, you can choose between the front or rear combo input. Then, on the screen, you select the type of source: instrument, mic, or line. A relay matrix routes the signal either through transformers or directly to the tubes. Bypassing is, of course, possible, and there's also a ground lift option. Each channel has a phase inverter and the possibility to supply 48V phantom power, but only when the mic input is activated.
If you select stereo mode, the settings from channel 1 are copied to channel 2.
Tube calibration
Given my background in automatic measurements for high-frequency systems, I added a program that calculates the gain of each tube to equalize both channels in stereo mode. This also led to the creation of a feature I hadn't initially thought of, which ended up taking a lot, a lot, a lot of time.
Auto Output level
In fact, you can activate the auto-gain option for each channel (1 or 2). How does it work? You set your desired output level, then you touch the clean or drive channel, and thanks to the magic of math and tube correction curves, your output level stays constant. Even if you open the feedback loop and suddenly add +10dB, the output level will remain unchanged. Essentially, the SRPP output becomes dynamic. This saves a tremendous amount of time when shaping your sound. You tweak the clean or drive channels, adjust the feedback loop, or try one last option that I’ll introduce... and nothing changes at the output.
BassBoost on Drive channel
The drive channel is equipped with a reduced bandwidth on the lower end of the spectrum to allow the clean channel to shine, as well as to enable the feedback loop to open. This keeps the sound very round, yet airy. It avoids the overly "liquid" effect on the channels. However, if you want to go a bit lower, with the bass boost, the drive channel switches to a different capacitor, allowing the ECC83 to open up the entire low end. As a bassist, I find this feature quite interesting.
Bien entendu, cette option est également compensée par l'auto-gain lorsqu'il est actif. L'incertitude actuelle est d'environ 0,3 dB pour ce système, et je pense qu'elle restera à ce niveau.
Options
You'll notice available space at the bottom of the motherboard. On each channel, there's the possibility to add, in thru bypass mode of course, processing cards – digital or analog, your choice. There are all the necessary connections to control them via multiplexed SPI links, along with audio inputs and outputs going to the mechanical relays, and the 5V, ±15V power supplies.
I admit, for now, I'm going to stop here, unless someone crazier than me comes out of their cave to improve this :-O
VIewer
There's also a page I’ve called the "viewer," which allows you to monitor the tube parameters (supply voltage, heating voltage, and the temperatures of the power supplies). It also tracks the usage time of the tubes. I don't have enough data yet, but I thought it would be cool to add. Regarding voltage control, it also manages the heating time – when they’re stable, it means everything is good.
The sound
Let's talk about what really matters – the sound. Well, I haven’t heard other G9s in person, so I visited all the studios in my area to compare. I was lucky enough to try some really nice gear, like Neve, UAD, Manley, and others that are a bit less known. Let’s just say I wasn’t too nervous, although at first, in the big studios, I was holding my breath (as we say around here). In the end, the sound here is a bit drier. The drive channel and the opening of the feedback loop help to emulate quite a few competitors. I can't fully describe it, but for vocals, it's proven to be very practical and versatile, less so for guitars, but really great for bass.
thank you
That was a fascinating topic to discuss. I have many other projects in the works, and I'm happy to share this with the community I've been reading for four years. I'm just a small French guy living in the mountains, and I'm about to take this toy to our rehearsal space. I've never spent so much time on a project, even when I get paid for it. Your feedback will be my reward, but please, don't be too harsh on the digital side – I know it doesn't win everyone over.
Thank you for your attention, I look forward to your comments. And a big thank you to the passionate people who have shared their knowledge – much appreciated!
I bought 2 of these that were nearly finished but had some issues, the gain goes into low volume fuzz if you go all out on the left and a ball bearing came out of the pot. Anyway what I wanted to say was how much better the Lundahls sounded once they replaced the cheap British ones. It's a great sounding Pre when you get quality trafo's in it. I'm happy and will use it.
Darn, that is a fantastic piece of work you've made there - a massive modernizing of the interfacing to the G9.
Is this a one-off, or are you considering publishing the project as a DIY possibility? In such case, you should most definitely start a new thread for that, so it dosen't drown in the 125 pages of G9-help that we have already
Much respect!
/Jakob E.
Hello Jakob,
I'm not really sure — this is the third version. The first one was an analog single-channel prototype, the second one was made of modules to simulate a complete analog channel and recover components. That led to this version, which is still a prototype. The code could be improved, and the VST for controlling it doesn't really exist yet. I'm transmitting serial data via USB, but I haven't pursued that further — it's still something to do.
The PCB, although not too expensive (under €100), is quite challenging to assemble for beginners due to the many SMD components. That being said, I have the complete BOM. It would be great to see this project live on, maybe even develop it further for other hardware. The schematic would need a bit of work to move away from the prototyping phase and perhaps offer a kit with a pre-assembled motherboard, but that would come with costs.
I don't really know; I suppose you know more about the open-source world than I do, lol. Anyway, everything is available in common open-source formats: KiCad, Arduino IDE, and Workshop4D for the screen.
