haima
DING! ;D
another success story
Dr-Mbogo said:Today I modded my G9 with an "outsourced" HV-PSU. 100Hz hum completely disappeared. It makes no difference in noise, if the G9 is connected or not; it is dead-quite.![]()
ruckus328 said:One question - what's the little black box behind the regulator? Bridge?
ruckus328 said:Also, anyone have any recomendations for a pilot light? All the lamps I can find seem to be 100mA. Thought about just running an LED with appropriate dropping resistor, but again, because of the transformer schemes, will lighten up the load an potentially increase the output voltage on the secondary xfmr (again though, don't know if the difference will be enough to matter)
marvelouzone said:ok, here's another long question...
I plan on using ecc88 on output stage. So far this is what I know:
Heaters: 6.3 volt 365ma.
My question on this is can I parallel off the output of d13-16(before 7812s) to run an lm317 to adjust for 6.3v. Will the current from first transformer(secondaries 2*15 50va) be enough to power both regulators? If this is yes, can d13-d16 handle the current draw from both regulators? I believe they are 1 amp.
With using the ecc88, I believe the plate voltage needs to be below 130v if i'm not mistaken.
I seen somewhere in the forum that a resistor needed to be used, but cant seem to find the post now. My question is what value resistor would I need to drop to proper voltage, and were would I put it? Is there somewhere I could just drop it in on the board, or would I have to do something custom to make it work? A small explanation would be appreciated.
question about a tube.. .
1976 Mullard/Amperex A-Frame 6DJ8 ECC88
Anybody familiar with these? I have to admit I wasnt born in 76(I'm a younger DIY'er) ;D The tubes dont say mullard, but the seller says it has been confirmed by date codes GAO over B6I4 GA? over B6I1 they in-disputably were made in Great Briatain by the Blackburn Mullard. I can pick up a matched pair for 75usd Worth it? Whats the big deal with the A-frame if any? I have to admit, I have really little knowledge on tubes and some of there circuits..
last question.. Does 320v on c14 an 310v on c15 seem out of spec? Only reason i'm asking is because I built power supply offboard. I know the voltage regulator will start working once there is a load, but does that voltage seem high to start with? If it matters I used 2 of the triode dual capacitors 100+100 uf caps. So 200uf for c14 and 200uf for c15? good or bad?
I could be wrong, but my reasoning Is that I read other members say that ec88 gives 6 more db when used on the output stage. I plan on using 12au7 on input stage, just wanted to try something different on output stage.jackies said:Why do you want to use ECC88? Maybe you should just build it with 12AU7?
I built mine with 12AU7, it works just fine.
ruckus328 said:Here's where I get fuzzy though - on the cap banks I have both the input filter cap's and output filter cap's grounds tied together and THEN going to my offboard power supply. From there a ground wire runs back to my main board.
