synnys said:Mic input not so good, the last three steps of the gain switch cause an eerbleedingly loud high pitched sound (around 3kHz) each of these three steps has it's own characteristic distorted sound..
Sergio said:Here is a pic of my G9 ;D
Majestic12 said:Another question concerning the phantom power. I adjusted it to exactly 48V with no mic hooked up.
When connecting a condensor mic to the input, the voltage drops down to 33V.
Should I check the TIP121 or is this just normal behaviour ?
synnys said:I measure 39,3 Volts of phantom power, but it's on "ground and +" or "ground and -" if i meausre between "- and +" there's nothing!
Majestic12 said:synnys said:I measure 39,3 Volts of phantom power, but it's on "ground and +" or "ground and -" if i meausre between "- and +" there's nothing!
It's supposed to be this way. Phantom power is fed to hot and cold. When you measure between + and - you will always read 0V...
MeToo2 said:Is the hum actually in your test set up, outside of your G9? [test with other sources, and a direct bypass of your source to test kit via another pre]
Is the hum equal on both channels? [if it is it points to a common cause like HT supply or heater supply]
Is the hum independent of gain? [if it is it points later in the circuit or output transformer]
Is the hum independent of source impedance? [check with a 200 ohm mic attached]
Is the hum channel related? [swap input and output conenctions and check if hum switches channel]
Is the hum louder on the channel closer to the power transformers [right worse than left => possibly points to HT noise leaking into 2nd stage]
synnys said:MeToo2 said:Is the hum actually in your test set up, outside of your G9? [test with other sources, and a direct bypass of your source to test kit via another pre]
My hum is loudest on the rigth channel, closest to the PSU (almost 30dB louder!). I Swapped channels and that didn't help. It is most certainly NOT independant of gain. i got all audio connections shielded thoroughly. haven't tried moving to the HT board yet. will be my last resort...
