Finished! I love the sound, and the microphone bass is fine without any hard roll off. Just -0.8db at 30Hz and -0.4db at 50 Hz (maybe a bit more on some gain settings).
The second channel is virtually hum free, I might guess a trace of the 50Hz hum only if I crank the interface gain to +40 db. The middle channel hum is audible though, but only if I have rested ears or press the headphone hard on the ear. It was worse before but I thought about trying to rotate the first transformer a bit. A 3cm or so turn and voila, hum is halved. But still there. Fortunately i can't say it has any impact on a real world recording.
Voltages are 240.2, 11.95 and 48.
I'm amazed at how much heat the 12V regulator puts out. I used a large copper heatsink and I'm very glad I did so. Jakob wrote something like 5W of heat but really it feels more like 50
I'm actually thinking about adding an ultra quiet computer fan over it because the caps under it must be cooking.
Total weight: 10 kilos.
The only problems I have now are:
-finding some cool knobs.
-improving transformers.
Something is definitely not right. Both are getting hot. Not burning hot but after 2 hours of testing, they are as hot as a room radiator in winter. Edit: just took them out of the box, it is the 12V one generating the heat. The 15 only gets warm. I am thinking about ordering a single custom made toroid with 265, 15, 15 secondaries.
I thought 265 because that is what i am getting in terms of AC under load at the PSU entry. Or maybe go for 275 and get slightly higher HT (i currently have 240 not 245) What I definitely don't want it to have to change any of the PSU parts.
