I'm just about to do the 7 pin connector. Don't have any cables here right now. Only option is leftovers from EA2503 transformers. Really thin... Too thin?..sahib said:The space available behind the 7 pin has always been a bit tight. You can get round it by using thinner gauge wire. It won't make much of a difference in that length.
Chunger seems to have used spacer to bring the connector forward a bit.
Thx! Thought so.. Found a few leftovers from the transformer in the bin. Will have to do!jplebre said:I'd say too thin.
20-22AWG for 1A ish. That's 6-7 modules (API spec).
Again, depends on the manufacturer of cable but
Thx Udo! Mind reading, because that's exactly what I did eventually. Cut a bit of the PSU cable. Also managed to bend the leads behind the 7 pin connector just as you described. No problem with the space and no need for spacers. A bit odd though... that every little detail is included in the kit, but not these cables (yes, the grey PSU cable of course...) and no screws/nuts to fasten the chassi mount 7 pin connector...kante1603 said:Hi Paul,
best to use the same you're running from the psu to your rack.Volker and Jeff use a 7 core with each conductor at 0,75 square mm ( roughly 18AWG).That's on the safe side.If you don't have it leftover just look at some old household stuff in the garbage or old computers,lots of fitting mains and psu cables to find there-and it's for free
Udo.
Addendum:
About the tight fit/little space behind the xlr connector.I always use a high temperature at short time when tinning the leads,this way the solder doesn't go too deep inside the wire and makes it
too rigid (hope that's the right word?).I then bend the leads over so they run in parallel to gain some space behind the xlr.Have never used spacers in any of my racks.
