veermaster
Is that a pinball ?
Amazing box!
Amazing box!
Bluebird, did you connected 6BA6's dirrectly in the triode mode or U used some resitors?I wired two 6BA6's to a 9 pin tube socket with buss wire kind of like the Manley T bar to eliminate some oscillation I was getting earlier when using 4 inches of wire from the 7 pin tube sockets to the 9 pin tube socket. Both adjustment points are at 7 volts.
5749 is more shock resistant... A kind of military specs 6BA6... But I can't say more for the sound... I bet it will sound the same. :Moby said:Guys, what's the difference between 6BA6 and 5749. Or is it 5749 good replacement for 6BA6 Vari mu ? Also there is 6660.... similar but how good?
Yes, I compared the sheets, looks similar (but not exact the same). I just wonder about sound. ??? Must be that it's less microphonics since it's industrial-mil tube .5749 is more shock resistant... A kind of military specs 6BA6... But I can't say more for the sound... I bet it will sound the same.
lolo-m said:One is a change in Analag's network but have the same compression signature, with a more program dependant maximum compression...
[snip]
The other is certainly more different, more "a la Fairchild position 1 compression".
Not at allNot that bad isn't it?
Is that recommended mod?One is a change in Analag's network but have the same compression signature, with a more program dependant maximum compression...
R17 : 221K
C3 : 100nF
R18 + RV7 : Fixed 10K
C4 : 1uF
It sounds really good if you like ultra fast comps. I do. There's a magic thing with the varimu comps : the compression is always very natural, quite impossible to hear...Moby said:how it sounds? Are you happy with overall results?
I'm trying to have a quick comp... I love quick comps... I will work on differents attack and realease times to have a really versatile compressor... I don't do a lot of mastering but because I'm always disapointed with others results, I would like to have a mix and mastering comp...Moby said:Are you tweaking 660 for tracking , mix bus or mastering purpose, or you want to have "all in one"Also, it will be great if you can do some sound samples. I will try your time constants but it will be great to hear results ;D
Yes, it is that one !Moby said:Is that recommended mod?One is a change in Analag's network but have the same compression signature, with a more program dependant maximum compression...
R17 : 221K
C3 : 100nF
C4 : 1uF
Of courseI will put a few samples online in a few days if you want...
