Hmm, with 6BC8 i doubt it's possible. Of course if you are talking just about T.constants maybe it's possible... I think that 6BA6 is better because of varimu curve, but that will be pseudo triode sound signature. I'm still waiting for my 6BA6's . Also I'm not sure about wiring in triode mode. Direct?I wonder if I should use this to get more close to the Fairchild compression style
You can't go out of the varimu curve of the 6BC8 in the PM670. The PM670 is a varimu comp.Moby said:I think that 6BA6 is better because of varimu curve
Yes I understand what you are talking about. I just wanted to say that 6BC6 has real varimu kneeBut the main "problem" if we can call this a problem, is the Side Chain amp IMO.
Great, I thought that it's dirrect triode connection ;D About voltage boost I can see in the first post. ThanksYes I wired the 6ba6 in triode. Pins 6,5,2 all together for the plate. and remember I boosted the voltage up to about 210 volts.
lolo-m said:I've got another working mod to make the PM670 be able to handle the Fairchild's time constant networks... and so many more... Cheap and easy to build !!!
Interrested ?
Yes, it is tested ! And it is working ! ;DMoby said:Did you tested the "thing" or it's just idea?
Yes, the idea is to have the possibility to plug the real Fairchild's model 670 time constants network... And many more !!!SaMpLeGoD said:Nice Lolo... so, boosting the Sc will can use the Time Constant's network from the original PM670 design? isn't it? is that the idea?
You've got it, I use the +17V/-17V of the PSU board. Because my relays ( and later leds... ) are not supplied with 17V, I had a regulator to feed them ( 78XX where XX is the voltage you need !): this is the additional V+.Kingston said:nice hacking lolo-m!
I guess the original PSU has plenty of power for all this.
so now you grab the "extra" +17V to your opamp, but also lose it for 12V gadgets (meters, relays)? Do you branch (regulate) the +17V down to 12V somewhere there as well, or did you just strap some resistors to your meters/relays get 12V?
Also, where do you grab the "additional V+" and how much did you intend this to be?
