Listen to your comp ! ;D ;D ;D
I will Lolo, I will
It's my 5th DIY comp
I'll use the PM670 on a mix next week, so I'll post the results
Thanksssss!
Eddie ;D
It's maybe here :mikeyB said:It's getting late and I can't find what I thought I had seen - maybe another thread -but didn't someone mention using a hybrid poweramp chip to replace the valve sidechain? Will this affect the sound drastically?
nite nite - need sleep!!
It will be nice if you can post some sound samples, 6N5P against 6BC8lewilson said:Hello all,
I have found the Russian 6n5p tube to be a nice sub for the 6bc8 tube, Much smoother fuller compresion and overall a better quality tube than the american tubes. Its the same pinout as the 6bc8 but uses more filiment current.
Is it a direct substitute ? I mean did you just plug them with the same settings or did you change the 2 bias settings ? I bought some to have different compression flavours on my 2 PM670...lewilson said:Hello all,
khstudio said:I made a voltage chart in EXCEL & a TEXT doc.
EXCEL VERSION = http://www.khstudio.us/DIY/PM670/PM670-VOLTAGE-CHART.xls
PL1 - Control Voltage (Threshold Off, Then 1st ON Position, Med & Full on) This one is tricky but important!
...Must have audio going thru unit, say 1.2v Test tone @ Input (Please measure AFTER connecting to input! due to loading)
& then set gain to have 1.2v at the output (with Threshold fully off)
Obviously everyone's measurements will be slightly off due the differences of Threshold controls, Taper & values chosen...
but if you KNOW your switch & values, posting the value along with the Voltage reading will be more accurate!
((((Sorry... This Test should have been added to the Test Sheet.))))
PLEASE DOWNLOAD & POST YOUR VOLTAGES... Thank You!
Below is the TEXT version & Attachment Version Below that.
PM670 Voltage Chart USER NAME =
"Inital setup" input gain & threshold control at 0
Measure voltages referenced to ground - Set RV3 wiper to -2.4VDC - Set RV6 wiper to -4.5VDC
Power Transformer & High Voltage output =
HR* = Heater resistor Value =
Volts - Before & After HR* =
VU METER "Type" =
POWER SUPPLY NOTES
KL1 AC-IN HIGH VOLTAGE AC IN TO DIODES
R1 Before 47r - 2w
R1 After 47r - 2w
R2 Before 47r - 2w
R2 After 47r - 2w
CHANNEL - 6BC8 - Section
PL1 PIN 2 CONTROL VOLTAGE - THRESHOLD OFF
Q1 Emitter "Common node voltage of R1, 2, 3, 4 = 330r"
R2 330r Cathode = V1a
R1 330r Cathode = V1b
R4 330r Cathode = V2a
R3 330r Cathode = V2b
PL2 Pin 2 Center Tap of T2 - 10k:600 - 136v from R6 / VU Meter
PL2 Pin 1 Outer Tap 1 of T2 - 10k:600 - Voltage to Plates - One side of R6
PL2 Pin 3 Outer Tap 4 of T2 - 10k:600 - Voltage to Plates - One side of R6
PL3 Pin 2 Should be same as PL2-Pin 2 voltage
PL3 Pin 1 136v INPUT - to R6 & VU Meter
CHANNEL - 5687 - Section
R10 330r "Common node voltage of R11, 12, 13, 14"
R11 47r Cathode = V3a
R12 47r Cathode = V3b
R13 47r Cathode = V4a
R14 47r Cathode = V4b
PL8 Pin 2 Center Tap of T4 - 10k:600 - 245v INPUT
PL8 Pin 3 Outer Tap 1 of T4 - 10k:600 - Voltage to Plates - One side of R15
PL8 Pin 1 Outer Tap 4 of T4 - 10k:600 - Voltage to Plates - One side of R15
I ran some tests, using 1x 5687 in the left ch & 2x 5687's for the right.
All of the voltages into & out of the sidechain section & the control voltages matched at various settings!
So then I did some "Burst" tests to check & see the "Attack Time" in the computer... they also were no different & appeared to be pretty fast (aprox 2-5ms)
Then I listened & could not tell a difference between the 2 channels...
I'd like to run the 670 with just One 5678 instead of 2 but I need to ask, what is the downside of this if any
& does the cathode resistor need to be adjusted & to what?
The Voltage at the 330r & 47r node is:
2 tubes = 12-13v
1 tube = 10-11v
The main reason for me wanting to run it like this is the HEAT is drastically reduced everywhere except the heater resistor.
I know the sidechain amp has a lot to do with the "Attack Time" but how is it that the One tube does the same job as having 2?
*** The Philips & newer Tung-Sol both reacted the same when doing the "single tube" test. ***
lolo-m said:Rowan's TC network doesn't need a lot of power to work... It charges a really small cap on attack...
khstudio said:I must say I'm really surprised that no one else is having issues with a HOT Edcor Power transformer.
Here are the readings:
Total Heater Current draw = 5.27 amps
15 min = 98 deg F
30 min = 110 deg F
45 min = 115 deg F
60 min = 120 deg F
90 min = 128 deg F
120 min = 135 deg F
At this point the PT is too hot to keep your hand on for more than 5 seconds... if that!
Here are the readings with "Just ONE Tube in the Side Chains" - Both Ch:
Total Heater Current draw drops from 5.27 amps to 3.58 amps
15 min = 95 deg F
30 min = 98 deg F
45 min = 103 deg F
60 min = 106 deg F
90 min = 107 deg F
120 min = 107 deg F
MUCH Better, no?
khstudio said:This is part of an email I sent to Rowan concerning using only ONE 5687 in the sidechain:
2 tubes = 12-13v
1 tube = 10-11v
Thanks for the info...
Do you see any downside to the one tube side chain at all?
What about charging the 10uF Cap?
less release (or a weird release action)
