Silvas
lolo-m said:As the thread is a bit long ;D, I re-found that. I hope it can help you:Silvas said:lolo-m said:The vu resistor have to be choosen well to track correctly the gain reduction. The movement is showing you some compression but maybe not the real amount of compression.
Hey Lolo, can you elaborate a bit more on this ? as i mentioned before, my meter is showing approx 1/2 of the real and measured gain reduction. Of course i would love to have a bit more accurate tracking, but i hadn´t played with the 22K VU resistor yet and my paralell trimmer is 5K. At first i wanted to take the 22K completely out and see...but i´m sure there´s a better way to select the resistor, then zeroing it with the trimmer.
This setting works or not depending of your 6BC8 curves...lolo-m said:You've got to understand how's the VUmeter is tracking gain reduction (maybe you already understood that but some of us can be interrested) :
A vu meter is a AC voltmeter (with the rectifier build in). Through R6, the current pumped by the 6BC8 creates a voltage you measure. As the tubes are pumping less current when compressing the voltage drops and the needle goes left. Some little maths : If we call Ib the DC current pumped by the tubes and Ia the current pumped by the tubes to create audio signals voltage on R6 can be calculated with this : Ur6 = [Ib + (Ia - Ia)] x R6.
You can use nearly any Vu or voltmeter here to track compression. On mine, I left R6 on the board and connected on parallel a 500 ohm pot (with 2 points wired together to react as a single resistor). One point of the pot is connected directly to the vumeter, the other point feed the Vu through a 3K6 or 3k9 ohm resistor. It works ! And my Vumeter is an old PEKLY (french brand unfortunately disapeared a long time ago)...
Try this if you didn't and tell us what's happening .
PS: the needle reacts weirdly only when the 6BC8 are overdriving audio (I mean with no compression).
Seems it doesn´t work with my Nissei VU´s...that was exactly my initial setup. The nissei VU´s has the 3K9 internally. Have to try it again now that my PM is working nicely. Thanks !
