today i had time for diy - the first time in the last six month so i tryed to solve the porblems with my pm 670.
if i insert only one 5687 on each channel the meaters are fine and i can adjust the rv3/6 but with two tubes per channel meaters wobble around. i tryed thre different sets of tubes. two sets (8tubes) "electron tubes"
http://cgi.ebay.de/5687WB-Roehre-neu-new-5687-Tube-OTL-Headphone-Amp_W0QQitemZ390178298607QQcmdZViewItemQQptZR%C3%B6hren?hash=item5ad8705aef and one set "ge" which i had in the storage. same problem with all of them;-(
then i matched the tubes with the voltage @ r10 as refference. i got two pairs one with 10,4v @r10 and one with 10,8V. now the meters are fine and i can adjust rv3/6.
but now there is another problem if i switch the threshold of the "10,8v" channel both the meter of the other channel is chanching the zerro point.
if i understand this right i have to match 4 tubes with the same resulting voltage @ r10...
am i right? anyone got a tip where i can buy four good 5687 tubes?
EDIT: there is no problem with the audio going throu the channels! no distortion and the compression sounds great.
all other voltages seems to be fine except 245v which is 252v on the psu - is this a problem? and i should change the heater resistor when i got the tubes working right.
