mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
emrr said:Today's bench test of the side chain amp; I'd show you a picture but you'd be scared. Pile of loose parts and test clips, bench PSU.
247VDC = 38 mA
13.7VDC at top of R10
-15dBm into T3 = -3.2dBm on sec
20.5dBm T4 pri = 8.3dBm sec
23.3dB gain through SC amp
Then disconnected T4 sec from rectifier, put 5K load on it, and did level listening tests.
By ear, looks like approximately 10 dBm max into T3 pri with threshold control fully open, which matches T4's max rating of 2.5W.
Worth considering when planning threshold attenuators.
This 2.4W is only for the threshold right? I mean, for the input attenuator we can use those little state ones (0.25W) like in the 1176?
