crisotop
I'd check for shorts on the psu pcb high voltage path (this is where the fault is occurring right? - your 245V rail is way off?)
yeah, well, you can't really expect me to read the first post in the help thread, can you?!?!?[silent:arts] said:from the first post of this thread
[silent:arts] said:
hole diameters are 3,1mm
radiance said:I've a couple of Lundahl 1517 transformers laying around.These are 1+1:1+1, so not ok as T2 replacement. But what If I used two of them, primaries of both in series, secondaries of both parallel. Result would be a 4:1 transformer with center taps.
Are these transformers ok for this ? http://www.lundahl.se/pdfs/datash/1517.pdf
I know the edcors can handle 2,5W. Can't find this info in the Lundahl datasheet though...
Kingston said:It's certainly an oddball combo to test so if you have the time let us know how you wind up. And don't get the many (4!) parallel secondaries mixed out of phase in output 4:1 usage.![]()
SmokingGun said:I'm guessing that the threshold control really is just the side chain amp gain?
Kingston said:But notice how the output of the 6BC8 amp already goes to an isolation pad (just another attenuator), then to the sidechain input transformer. But this is a 10k load. Adding a 600-ohm attenuator in between here will hurt output drive capability.
emrr said:Kingston said:But notice how the output of the 6BC8 amp already goes to an isolation pad (just another attenuator), then to the sidechain input transformer. But this is a 10k load. Adding a 600-ohm attenuator in between here will hurt output drive capability.
It's a 1K8 load with a 10K shunted across it. It's being driven by a 600 ohm source, so a 600 ohm attenuator would work fine, and the existing R7-9 isolation pad would still present a minimum condition as designed. A 600 ohm T that is set for almost minimum attenuation is about a 5K shunt load, so no damage at all. But, a 600 ohm T or ladder here potentially affects the balance of T2 output to the outside world, if you care about such things. I don't.
radiance said:Basicly, I'm a tube noob.
So now I'm matching tube's for the first time using lolo-m's test setup. (thanks for that lolo!!)
radiance said:what is a close match?
For example: with the VU meter at -1dB, one tube reads -2,45V and another reads -2,35V. I know, the whole curve should be matched but is a 0,1V difference a close match? I have tubes with 0,5V differences as well BTW.
Also, should tubes be burned in (& for how long) before I match them? AND is it OK to match to use tubes from different manufacturers as long as the curves match?
melville said:Thanks for that Radiance. Am I missing something with the search function?
"tube tester" didn't find that for me. The site search not the google search.
Anyway enough off topic.
Sorry :-[
