hey guys, to add one more.. I finally got mine to "work" without the excessive hum and buzz I had before. Mine is still naked, so there will be some improvements once it's in a case.. I have a one channel build, PSU is "corrected," per analag's comments, with a 0.33uF film cap (what I had around) instead of the 47uF on the schematic/BOM. All else is stock, but it wasn't working, so I added 4x6800 uF to the heater supply, 13600 before the big resistor and 13600 after. Made a large difference in hum, and my meter finally worked (it lives pegged to the right until compression occurs, then shows compression, but after I stuck the caps in it went to 0VU). Anyway, I still had noise and hum which sort of oscillated, so I then removed one 5687.. After that and swapping the large resistor to get the voltage closer to 6.3, it worked fairly well (but my meter went pegged again).. There is still some hum (didn't check SNR so I can't tell you how far down, but I can't hear it under normal conditions, just if I have my phones or monitors at full volume. Anyway, it sounds nice so far, I'll probably mod the time constants eventually, but I am glad I kept this thing. Maybe I'll do a second channel P2P.
anyway, to those of you who had this problem where removing one 5687 made the thing work, how did you handle it finally? Radiance I saw your build has 4 tubes per channel, so you must have used other tubes than the originals you had (IIRC you had this problem initially)?? KHStudio, you still have this issue?
Is this just a matter of mis-matched tubes?
thanks!
