skal1
cheers
skal1
analag said:![]()
R1 should be 10W 50R - 100R and R2 2W 150K - 75K depending on your situation. Tweak the values so that you have 310V - 320V going into the regulator under full load meaning when the tubes are conducting/working or whatever you wanna call it.
dingo said:hello still having problem with the high voltage rail
with the analag mod both channel connected all tube voltage reach 245v than start floating from 210 to 190??? ???
can see the meters moving with the voltage floating
if i use just one channel it work and sounds great
do not matter which channel i use... but just une chanell...
so my idea is to build a second psu for the other channel maybe a semplified version without all the small trnstrs
just the high voltage rail (245+136)v
build the 245vpsu rail like the 136v rail on the schematic it is possible?
dingo said:hello radiance
my slow start heater have is own transformer 100va 9v(lot of juice) both slow start have sep. bridge rect. not using rondo 9v section
transf any more .
same with relays lamp and scamp booster have separate power supply pcb with 24v (m-nats one )and dedicated transformer
the rondo is just driving +17v -17v and the high voltage(245 136 v)
so is just the high voltage failure !! :-\
transf any more .
mich said:yes,these sc tubes are almost like 6L6's in power consumption and heat...
Silvas said:I just had an idea. It is possible to use another kind of tubes in the sidechain ? of course via the appropiate adapter ? i´m thinking on something that run less hot and draw less heater current from the PT...anyone has tried something like this ? Just don´t shoot me if it´s not quite a good idea !
I´m currently running my PM on 1 5687 per channel, and my PT is hot.
kazper said:it's been mentioned before that if you powered the 5687 with 12V heaters over the 6.3V it would help since were paying a price to drop the voltage on that power resistor anyways. I'm also thinking that most of the power transformers are running close to there 100% rating and should have been specified larger with some breathing room.
