[quote author="khstudio"]Could I get an estimated value for R15
the "Off board 25/50W resistor" for the heaters
[/quote]I too am wondering what to get, but I did not get a group buy power trafo because I thought it was a waste of $$ for only one channel (I am doing a 660). so I have a couple of questions..
1) What is Analag using for R15 in his 660?
2)Also, when did we go from 6.3 to 9V? Is this specifically for the 670?
This is what Analag said his power trafo is :
250V @ 80mA, 15V @20mA and 6.3V @3A.
Is Analag using the bypass boards?
Finally, the toroid I am looking at (Antek 1T250, someone mentioned this here or in the "should I" thread but gave the wrong specs) is 2x 250V, 250mA each ,2x 6.3V 3A each.
Can I get +18 and -18 from one 6.3V 3A secondary... or wiring the two together, but I think it~s not a good idea to mess with the heater voltage.. . I don't want to buy two toroids for this, so I may ask to build Antek if they can custom do one, but no idea if they do that. Unless you think it'll work with this one (with bypass) I will have to keep looking. Thanks for the ideas..
On a side note, I traded a few emails with Laura at TAW about their products in general and Wimas specifically. She will probably appear here herself at some point, but for the time being she has offered anyone from Prodigy their 100+ pricing on small orders... The 10uF MKP4's turned out to be $4.15. I ended up ordering all the Wima's I need now, for much less than Mouser, plus all the Panasonic electrolytics which are also a few cents cheaper than Digikey. I'm gonna post this in the BM for those who want to take advantage.
