radiance
dagoose said:The 'regular' sidechain is stock (ok, via the scamp circuit) and the scamp booster is build exactly like in the attached schematic.
The connection labelled "R-L Conn_2" & "C-L Conn_2" allows you to connect a rotary (or whatever) to switch between different caps and resistors. That was what I was asking.
dagoose said:It's the sound, it's just a bit muddy/dark and missing bottom-end which i really think is coming from the input trafo's.
Why do you think it's the input trafo's?
dagoose said:I have no way to match tubes so no.. tubes are not matched. How did you match 'm?
Read this thread again starting here: http://www.groupdiy.com/index.php?topic=28274.2160
Lolo-M posted a schematic for a tube matcher which can be made on vero board.
I might have mine left somewhere...plus some tubes from my matching endeavours...PM me if you're interested. I've also some russian tubes (which I ended up using BTW) left.
But really, if you want to resurrect your poorman, read the thread starting at the link I posted above.
A lot has been learned about this project since you finished your poorman I guess....
