What voltage are rated the caps used here, in the time constant mod ??
63V is enough ??
63V is enough ??
idylldon said:mitsos said:What are the bluebird timing mods?
I believe most of this is from bluebird with some other info from other folks (sorry, didn't note who wrote what):
The Main mod I wanted to suggest has to do with the time constants.
I just wasn't getting the flexibility out of the attack and release I wanted.
So I started off by adding a switch to change C4 (10uF) I used these values.
10uF, 6.8uF, 4.7uF, 1uF
I still felt like the attack knob wasn't changing the time constant enough.
I glanced over the original 670 schematic and realized it has a resistor in parallel with the time constant caps not in series that changes.
EDIT I'm sorry there are also resistors in series with the capacitors in addition to parallel. these would have an effect on attack time. EDIT
So basically I PUT (RV7) IN PARALLEL WITH (C4).
I put RV7 on a 5 position switch and used these values:
25K, 65K, 150K, 470K, and an open position (you could use 2 megs)
The higher the resistance the longer it takes the cap to discharge through it. longer release. the smaller the cap the shorter time it takes to fill up. shorter attack.
switching up the combination of the two makes for a lot of flexibility.
Voltage rating of caps: there is no high voltage in this stage. In my opinion you are fine with - let's say 63V.
I wanted to mention an easy way to get a good range of time constants without big changes is to just use the resistor values I mentioned earlier in parallel with the 10uf cap. You don't really have to change the cap value to get a good variation of release times. It has a lot more effect than the stock 10K pot in series with the 10uf cap.
I've scaled back to three caps. 10uf, 6uf, and 2uf. Also using just three resistors in parallel with the caps. 68K, 470K, and 3m (or no resistor). With those caps and resistors you can simulate the first three or four time constants of the real 670.
I've been using the 2uf and 68K in parallel setting the most. this is closest to the fastest fairchild setting. its great on bass drums vocals, just about anything. I'm sure its not the exact same because of the weaker sidechain but I'm loving it
I should also mention that I don't EVER use the Analag/Rowans original time constants because they are WAY too slow I used "Bluebirds" advise & set up a 2uf cap with various "switchable" resistors for release times. I think 68k, 180k & 470k then one position with just the 2uf (no resistor). My position 5 is blank for now & 6 is Rowans 10uf. These combination's work GREAT for vocal, bass... most things really.
Note to everybody: in Analag's design, the faster attack is with the 10K pot set at 10K... The lower it's value, the longer is the attack or to be precise the softer is the attack... The release time is function of the program which charged the network. More clearly, if the comp compress during a short time, the 10uF will be charged during a short time and the release will be quite fast. If the comp compress during a long time, the 10uF will be charged more and its discharge (release) will be longer... It is an adaptation with really interesting attack/release of the position 5 and 6 of the Fairchild.
The original design has far too long release times for my taste. I tried to measure the release time, got bored, went for lunch and when I came back the meter returned to 0vu. About 25 minutes i think. (joking)
So, I took out c4, jumpered it and substituted it with different capacitors and resistors in parallel.
At the moment I have:
1u2 // 50k
3u3 // 100k
4u7 // 150k
5u6 // 1meg
6u8 // nothing
10u // nothing
Mind you, these are just values I had in hand. I installed them in order to start aurally tweaking the beast. BOOM!!! I haven't taken it to the studio yet, but listening at home I can easily see the poorman becoming my favorite compressor.
Beautiful compression action, especially with those short release times.
So based on what you explained (thanks by the way), my table:
Slow attack Fast attack
10uf 6.8uf 4.7uf 2uf 1uf 0.5uf
None 2M 470k 150k 65k 25k
Slow release Fast release
Bluebirds schematic can be found in this post:
http://www.groupdiy.com/index.php?topic=29056.msg369127#msg369127
Back to me. I did a similar mod to mine based on Kevin's (khstudio) suggested values, which I've forgotten right now but maybe he'll chime in to mention them. This TOTALLY transformed the compressor into something FAR more usable and flexible. Even though I loved my 670 from the beginning, I REALLY love it now.
Don
