[quote author="no-fi"][quote author="jdbakker"]
It would help us in helping you to have a more precise location than the one currently in your profile. From your earlier mention of AU$ I'm guessing 'somewhere in Oz', right?[/quote]
you're right.
Sinney, oztraya. maaaaate![/quote]
Ah yes, the first and only place where I've ever seen a sign at a park entrance saying Please walk on the grass.
[quote author="no-fi"][quote author="jdbakker"][*] From what [silent:arts] has written I gather that any 10uF polyprop cap that fits the PCB will do. This excludes the Solen Fast and similar (large) cylindrical caps, and I would personally be wary of no-name Shanghai Specials. It doesn't have to be a WIMA, if you find a polypropylene film part from EPCOS, BC, Panasonic or AVX that has a similar footprint it should work Just Fine. You can get the footprint by measuring the slkscreen on the PCB, or from the WIMA datasheet.[/quote]
hmmm.. ok, in that case, I probably need the big WIMAs... apart from huge 400V solens, I can get something locally, made by a company called farad - http://farad.net - but I guess that would count as a "shanghai special".[/quote]
They're pretty much the poster child for Shanghai Specials, yes. [I needed to reformat the URL as http://www.farad.net , BTW]
[quote author="no-fi"]apart from these, 10uF polypropylene caps are pretty light on the ground.[/quote]
If you're just looking for an inexpensive way to check whether the circuit works before ordering the WIMAs (/while compiling a larger WIMA shopping list), those parts should work OK, as would Polyethylene/Mylar film caps or (in a pinch) low-ESR bipolar electrolytic capacitors. They may not sound the same as the Real Deal, and the heat from the tubes may shorten their life considerably, but it should work nonetheless.
JDB.
