C12 with 6S6B-v triode, we are launching the project.
Papa Tango Charly
GDIY Supporter
Paris
Hello, Here is my new schematic for C12 with a 6S6B-V i will probably use the original Apex 460 transformer + capsule C12 "CTS3 omni from taskar".sold buy Vami.
Tbone Black PSU.
Do you have any suggestions, or advises?
I was wondering if C4 1uf would be a good choice for the 6S6B-V
Thank you all for your cooperation!
And you might want to add a 100n or so from the R4/R5/R6 node to ground.
PS. Looks way more like a 251 schematic than a C12, between the self-bias and the 100p coming off the plate.
PS2. And who is this "we" that are "launching the project"?
Hello guys thank you for your help I have 3 x 6S6B- V we are building 2 mics with a good friend in the old Apex 460 body’s We are about to build the pcb.
R9 = 10 K
Is 10k the original value? Not 10M? what will it change. TK best
What will it change can you show where to place it. TK best
How much clearer of a description do you need? Or if even that's not clear enough, should you even be poking around dangerous-voltage circuits in the first place?
Well, 10 MEGOHMS in series with the tube supply won't leave any voltage for the tube. Ohm's law, anyone? How did you arrive at that value, anyway?
Thank you for your concern Khron. That’s why I’m not doing it alone…
So the 100nf should be place after R6 before the ground right? Does the value of the condo has a impact on the sound.
thank you
