[silent:arts]
they are
Sorry, must be that I missed that. Where is the sweep measuring of the unit?the in-circuit sweeps of completed units we've seen haven't shown any ringing, so i wouldn't worry too much.
Volker, are the steps in the Excel sheet calculated for 1db attenuation per step? If not, can you tell me about?[silent:arts] said:the rotary switches
you would better want it exponential (or log in potentiometer language).
it took some time to figure this out, but with some help I was able to do an Excell sheet to calculate the resistors for emulating a real log potentiometer.
fill in the desired steps you want: Log Pot to Switch Excell Sheet
you may want it in dB steps (like me). at the end it is a series attenuator.
my prototype has 18dB of gain, thus I will do one dB steps on an Elma, stopped to 23 steps, going from -4dB to +18dB.
Of course, round the numbers, I've been precise to let you choose the closer value... I will do the sameMoby said:;D Thanks... I was always poor in math so I will round the numbers
You don't really need shorting switches for the time constants IMO. The only thing that will occur will be weird attack/release during the switching operation... It will take a few microseconds to go from one step to another so...Mr. Snoid said:I scored some cheap retired grayhill 70BFD30s for Fabio's 1270 build a while ago and was wondering if I SHOULD use them as Time Constant switches.
The problem is they are non-shorting, but I could stop them to 6-8-or even 10 position and solder the resistors to the PC board connectors. Would save a few bucks...but is the non-shorting issue a big deal? Could it be compensated for easily with a cap perhaps?
Or should I just say "**** it" and buy some 2x6 Lorlins? It's only money, right????
Tod
If you've got time enough, it's certainly better to match them, but stuffing those switches is already a long work so... If you take 1% resistors, your switches will be matched certainly at less than 2% ( 2% is the worst possibility if you buy following resistors in the same bobin )... It's always better than any pot !!! ;DSaMpLeGoD said:Quick question, for threshold and gain ,I bought on ebay 4x 24 steps rotary switchhes with double deck for my PM670... just need to ask one thing: the values obtained in the Volker's datasheet need to be present in each deck... matched??
But the gain switches don't seem to work.
