Gachet
;D Not the prettiest but it does the job
Thanks Analag and Silent art
RedNoise said:Do these sosckets melt down cause of tube's heat ??
bernbrue said:Did you tie the time constant controls of both channels together?
bernbrue said:In my unit it´s the rectifier for heater supply that is getting quite hot.
So you left C4 10uf and you just added pot across it to "speed up" a time? 500k/log? Why not linear?The attack control is the normal time constant on a stereo 10K lin pot.
The "so called " release is the suggested bleubird mod:
I've tied a 500k log pot parallel to C4.It results in faster release settings(to my hears)
I can switch it back to original with the "mod" switch to compare.
So there is some sound change Good to know, I still didn't tried :-\I've tried both schotky and 1n4148 diodes with the dip 8 socket trick .After some audio testing I kept the 1n4148 but this is very subjective.
Did I understood correctly? You turned the pot into tapper with stop value of 10k max 14,9K?After the mixing sessions I changed the treshold steps and they are following (in ohms):
1-500 ,2-500 ,3-100 ,4-200 ,5-300 ,6-400 ,7-500 ,8-500 ,9-500 ,10-500 ,11-1000 + 10000 wich is not selectable.
It means that I have control from 14,9K to 10K attenuation for the treshold.
Bonne annee !!!Gachet said:I add a fan for the european transfo wich is heating a lot to me .
Moby said:So you left C4 10uf and you just added pot across it to "speed up" a time? 500k/log? Why not linear?
Moby said:So there is some sound change Good to know, I still didn't tried :-\I've tried both schotky and 1n4148 diodes with the dip 8 socket trick .After some audio testing I kept the 1n4148 but this is very subjective.
Moby said:Did I understood correctly? You turned the pot into tapper with stop value of 10k max 14,9K?After the mixing sessions I changed the treshold steps and they are following (in ohms):
lolo-m said:Bonne annee !!!Gachet said:I add a fan for the european transfo wich is heating a lot to me .
I'm surprised your transfo can get hot.
The EMRR test that closed the too long discussion about regulated or unregulated filament PSU makes me think that the filament can eat a lot more current than they should. Getting hotter the resistance of the filament seam to lower... That would explain the little voltage raise during the test... But that would mean extra-current out of the transfo if you didn't put a high enough resistance... :-\
Try to know how much current goes through the resistor... It should be 5,2A... If it's more, here is your problem !!! If it's not ??? ??? ???
Let us know, this is weird and interresting...
Just for fun, I measured the resistance of the filament of a 5687WA... About 2,4 ohm each section meaning 1,2 ohm parraleled... So I'm sure filaments doesn't follow the Ohm's law... Getting hotter their resistance grow... It would be interresting to know how !!!emrr said:The filament is really quite simple. A given current at a given voltage.
lolo-m said:Just for fun, I measured the resistance of the filament of a 5687WA... About 2,4 ohm each section meaning 1,2 ohm parraleled... So I'm sure filaments doesn't follow the Ohm's law... Getting hotter their resistance grow... It would be interresting to know how !!!
Of course it's not stupidThis doesn't mean unregulated PSU is stupid or... It just explain why unregulated PSU is safe !!!
