noulou
Just power it up with nothing connected if you want to measure your voltages.
Everything apart from the heater psu is actively regulated.
[silent:arts] said:rrs said:D9 Anode = 392V
D9 Cathode = 211V
D8 Anode = 392V
D8 Cathode = 394V
looks like your first regulator (around Q4) doesn't work
skal1 said:hey i just finished stuffing psu ,can i power it up with a load or will this cause damage to the psu
regards
skal1
Purusha said:What about with tubes IN?
This raises another question though.
I initialy mesured 136V on the connector pin where indicated when first powering up and was correct. Didn't mesure 245V.
After doing this I plugged in the two PM660 boards with valves inserted to mesure the requires R15 resistance. I noticed though after doing this that when I turned one of the threshold knobs that I got a spark on the PSU board around this "Q4" general area so am wondering the cause of the IRF820's failure and could it happen again. I am using the greyhyill rotary non-shorting type.
Mfr Part#: 71BD30-02-1-AJN
Allied Stock#: 948-7249
I don't want to have to replace it a second time as removing the first seems to have not been easy for me or on the PCB.
Also R10 330R on both PM660 boards is burnt out I guess due to the incorrect voltages being pummped through it.
Thanks will try.noulou said:Leave the machine on for more than half an hour with case closed in order to get warm in there.
The filament voltage will probably rise.
klaus2you said:Noulou, thank you for your reply! It's been really helpfull, wiring was fine but one of my lorlin was faulty. Regarding the meter i originaly put a 22K trim in place of R6 but was afraid to go so low, but you where right two turn of trimmer after my vu finaly read 0.
For those who used sifam AL20SQ like me, substitute R6 22K with a 47ohm or little higher.
Noulou again, thanks!
Did you checked the Edcors. Try to measure them , for start dc resistance...I am using the same Sifam AL20SQ meter which had the same problem. Have replaced R6 on both boards with 47 ohm resistor but 1 meter (Closest to PSU) is still Flexed hard right. The other channel is at about 3 db GR so will try the 69 Ohm .
Any ideas why one channel is still a problem?
Moby said:Did you checked the Edcors. Try to measure them , for start dc resistance...I am using the same Sifam AL20SQ meter which had the same problem. Have replaced R6 on both boards with 47 ohm resistor but 1 meter (Closest to PSU) is still Flexed hard right. The other channel is at about 3 db GR so will try the 69 Ohm .
rrs said:Thanks Moby
I'm pretty rough on this stuff so if you can tell me what point to measure and what mesurements to look for that well help.
My skills beyond soldering and conecting parts are extreamly limited.
Try to measure resistance on the 10k/600 (T2) from pin1 to pin2 (around 215ohm) and from pin4 to 2 (around 240ohm). If the resistance is the same on both channels than you don't have a problem with Edcor's ;Drrs said:Thanks Moby
bernbrue said:rrs said:Thanks Moby
Before changing R6 I would adjust RV3 to 2.4V and RV6 to 4.5V for both channels. Since the these trimmers also influence the meters, this might be a chance to get both meters right.
regards
Bernd
