inputoutput
Following up on my previous post a few days ago. As mentioned, the voltages dropped fast when one or several tubes were inserted. So now, finally got my voltages right, also with tubes. i've been looking for shorts on the audio-pcbs for weeks, but it must have been something with the voltage-regulators. I changed them from two IRF840A into two IRF840B ! Looking at the voltage-regulators spec-sheets, I don't see why this should make much difference, but it does certainly work now. Another option might be that I had too much thermal compound, and that the heat didn't transfer fast enough. Anyway, it could also be the 840B that made the difference. So all you guys struggling with voltage-drops. Take a look at the those regulators again.
I am glad I bought a big chassis, cause placing of the Edcors play a important part in lovering hum and noise. So I'll move those around, and post a report as soon as I'm happy with the result.
small question : I've got 0.8 VAC in my heaters. Does a little AC in heaters matter in tube equipment?
