Yeah Volker what the hell is taking so long???
:wink: :wink:
:grin: :grin:
(im just kiddin')
Heres a List of most of the stuff from mouser PSU and Pm660 - I'm building a dual unit and ordered extras, Use at your own risk, I usually never get everything (or all the right parts) on the first order:
4 647-LGQ2W221MHSA 4 8.930 35.72
Nichicon Snap-In Alu
4 273-22K-RC 4 0.100 0.40
Xicon 1/2W 1% Metal
22Kohms 1%
4 273-10K-RC 4 0.100 0.40
Xicon 1/2W 1% Metal
10Kohms 1%
2 273-4.7K-RC 2 0.100 0.20
Xicon 1/2W 1% Metal
4.7Kohms 1%
4 273-470-RC 4 0.100 0.40
Xicon 1/2W 1% Metal
470ohms 1%
10 273-330-RC 10 0.100 1.00
Xicon 1/2W 1% Metal
330ohms 1%
8 273-47-RC 8 0.100 0.80
Xicon 1/2W 1% Metal
47ohms 1%
2 610-2N6107 2 0.780 1.56
Central Semi Power T
PNP Med Power
8 78-1N4148 8 0.030 0.24
Vishay Semiconductor
100V Io/150mA T/R
4 505-MKP410/250/10 4 12.660 50.64
WIMA Polypropylene F
250V 10uF 10%
2 505-MKS21.5/63/5 2 1.960 3.92
WIMA Polyester Film
63V 1.5uF 5%
2 505-MKS2.022/63/10 2 0.230 0.46
WIMA Polyester Film
63V .022uF 10%
2 647-UVR2V470MHA 2 2.380 4.76
Nichicon Radial Alum
350V 47uF 16X35.5
6 647-UVR2V101MHD 6 1.780 10.68
350V 100uF 18X40
4 647-URZ1E472MHD 4 2.530 10.12
25V 4700uF 18X25
8 647-UHE1H102MHD 8 0.980 7.84
Nichicon Low Impedan
50V 1000uF 12.5X40
4 647-UPM1H101MPD6 4 0.620 2.48
50V 100uF 10X15
4 647-USR1V100MDD 4 0.240 0.96
Nichicon 7mm Radial
35V 10uF 4X7
4 594-5083NW47R00J 4 0.320 1.28
Vishay/BC Components
2watts 47ohms 5%
7 273-221K-RC 7 0.100 0.70
Xicon 1/2W 1% Metal
221Kohms 1%
5 273-182K-RC 5 0.100 0.50
Xicon 1/2W 1% Metal
182Kohms 1%
5 273-150K-RC 5 0.100 0.50
Xicon 1/2W 1% Metal
150Kohms 1%
5 273-560-RC 5 0.100 0.50
Xicon 1/2W 1% Metal
560ohms 1%
5 273-475-RC 0 0.100 0.00
Xicon 1/2W 1% Metal
475ohms 1%
7 273-120-RC 7 0.100 0.70
Xicon 1/2W 1% Metal
120ohms 1%
5 273-121K-RC 5 0.100 0.50
Xicon 1/2W 1% Metal
121Kohms 1%
100 534-2027 100 0.250 25.00
Keystone Spacers and
RND .187X.500 ALUM
4 505-MKS4.1/630/10P 4 0.740 2.96
WIMA Polyester Film
630V .1uF 10%
4 505-MKS2.1/63/10 4 0.230 0.92
WIMA Polyester Film
63V .1uF 10%
6 652-3296Y-1-502LF 6 2.200 13.20
Bourns Multi-Turn Tr
3/8" 5Kohms Sealed
40 583-1N4007-B 40 0.030 1.20
Rectron Rectifiers -
Vr/1000V Io/1A BULK
2 512-1N4747A 2 0.080 0.16
Fairchild Zener Diod
20V 1W ZENER 5%
2 78-1N4764A-TAP 2 0.050 0.10
100 Volt 1.0W 5%
2 512-MPSA42 2 0.130 0.26
Fairchild Small Sign
NPN Transistor
2 512-MPSA92 2 0.150 0.30
PNP Transistor
2 844-IRF820PBF 2 0.840 1.68
Vishay IR Single-Gat
N-Chan 500V 2.5 Amp
1 512-IRF840B 1 1.700 1.70
Fairchild MOSFETs
500V N-Channel B-FET
1 512-LM317T 1 0.430 0.43
Fairchild Linear Reg
TO-220 1.5A ADJ VREG
1 512-LM337T 1 0.550 0.55
1.5A Neg Adj Vol Reg
1 625-GBPC1202-E4 1 4.720 4.72
12 Amp 200 Volt
4 532-529802B25G 4 1.380 5.52
Aavid Thermalloy Hea
TO-220, VERT 3.7 TR
