I haven't been around here for a while because (as some of you know) I had my share of problems with my build but I must say I learned a LOT about Vari-Mu comps!
Just to recap, I'm running my unit with just ONE tube in the side-chain & it works well & keeps my unit running MUCH cooler.. especially the PT.
I spent soooooooo much time on this thing... WAY more than I've ever had to with anything I've ever built. After finding that the "Tubes" (Philips) were the culprit I switched to "Tung-Sol"
I did everything I could from matching tubes, changing PT & swapping Edcore TX's & I found that the PM670 is what it is.
I had to say **** it & put it in the rack (even though it DOES have a little too much distortion/color for full 2 buss material.
What I do like it on the most is Bass guitar... Regular guitars, vocals, etc... are sometimes cool too.
I should also mention that I don't EVER use the Analag/Rowans original time constants because they are WAY too slow
I used "Bluebirds" advise & set up a 2uf cap with various "switchable" resistors for release times. I think 68k, 180k & 470k then one position with just the 2uf (no resistor). My position 5 is blank for now & 6 is Rowans 10uf. These combination's work GREAT for vocal, bass... most things really.
I wish I could clean up a little bit of the distortion that occurs MOSTLY WHEN COMPRESSING!!!
The RAW gain, with NO Compression on my unit sounds pretty good.
If anyone finds a nice alternative to the Edcore TX's, PLEASE let us know... maybe this would help with the "Sound or distortion" I'm getting, who knows ???
For those of you who that have questions about my build, problems, setup, fixes etc... you'll have to read back in the thread.
I don't have time or energy to retype it all.
One thing I dropped the ball on was posting the voltage chart of my own build but it did match what Don, idylldon posted.
