benlindell
And the 1062ohm resistor from each deck get tied together and sent to the PCB correct?
RayBlack said:Hey there,
I'm new here and need some orientation. Would like to build a Stereo Compressor for my 2bus, and the PM660/670 seems to be the perfect match.
Any information of the total costs of building the standard analag design, with a simple enclosure ?
Ray ;D
skal1 said:Hi
the poorman is causing my proceeding compressor to low signal .
1}set up is ,daw to compressor , tx 10k:600 output impedance into input tx 600:10k of poorman into mixer, why am i see signal loss in the first comp?
2}set up is ,daw to compressor ,tx 10k:600 output impedance into mixer, no signal drop in this set
is the poorman causing a loading issue ?
skal1
Your mixer has got a high impedance input. PM670 has got low impedance input.skal1 said:hi lolo-m
i took the mixer out of the set up and the level of the first compressor is still showing the same signal lost when the poorman is connect.
What do think is wrong here?
skal1
lolo-m said:Your mixer has got a high impedance input. PM670 has got low impedance input.skal1 said:hi lolo-m
skal1
The "problem" isn't your mixer. The "problem" comes from the compressor out to PM670 in . To be honest you don't have any problem if the loss is around 6dB with the poorman inserted between the compressor and the mixer. Simple ohm law applies there:
P = R x I x I
If R is divided by 2 it will result in a U divided by 2...
PS : Are that the chains you tested :
1°) DAW into compressor into PM670 into mixer
2°) DAW into compressor into mixer
If they are , and if the loss is around 6dB on the first chain, I think it is normal.
lolo-m said:Yes it seam to be right if the signal loss is around 6dB...
This is one of the reason that make the studio electronics manufacturers avoid transformers ( even if the main reason is the cost of transformers ).
To get a connection without too much loss between 2 transformers, we should have an output impedance of less than 150 ohm to feed the 600 ohm input transformer of the following gear... With tubes, it become really tricky to get this kind of impedance on the output...
And bump, BTW what is this comp ?
Should this happen ? NOskal1 said:everything seems OK ,until you start turn the gain switch connected to the transformer , the vu on the chas&dave moves down when the gain switch is turned ccw and up when turned cw.
It seems like the gain switch is acting like an attenuator for chas ,should this be happen ?
1°) A transformer hasn't got any impedance.
