The T188 Transformer
opacheco
HONDURAS
I found the following data (here in technical docs) for the T188 Transformer used in the TAB U73:
Haufe T188
Coil body EI 48/21 two chambers
Right chamber
515 turns 0.06 silk copper enamel wire
Copper foil
1030 turns 0.06 silk copper enamel wire
Copper foil
Insulation
Left chamber
same, wound in opposite directions
Do someone know what kind magnetic material was use for this EI 48 transformer laminations?
Was this a common FeSi magnetic material or special magnetic meterial?
Is possible found any supplier for or similar?
opacheco.
Pretty sure it’s the same lams as the V72 output transformer. And that was some kind of mumetal. Not that high nickel content as V72/76 input transformer but I think something like 40%. Maybe our member @flatresponse knows more as he analyzed original ones and sells a new version.
https://www.manfreddeppe.de/english-1/for-sale/
Murdock, Thanks for your response and comment.
In the Manfred Duppe website (your attached link) say:
"...one of the rare german sources of EI 48 mumetal core material still being produced in Germany we were able to develop a replica of the venerable T188...Grading has changed over time, but this material is something in between "Dynamoblech IV", the old (pre WWII) core material for transformers and a modern equivalent. I doubt, the old "german gun - material" does in fact produce the desired "sound"..."
Your comment look like very similar to the Manfred Duppe data there.
1-What will be the original T188 EI48 lams thickness?,
2-How we can to know the Mu-metal (nickel–iron soft ferromagnetic material) exactily alloy for this T188?, Do exist any kind of test for?
opacheco.
The Sowter V72 transformer data show a "100% Mumetal" core but I don´t know what this means?. I know Mumetal is a Nickel-Iron alloy and the percentage say the quantity of Nickel in there: Do the 100% Mumetal means a alloy 100% Nickel and 0% Iron ??
opacheco.
    32.4 KB
