The T188 Transformer
opacheco
HONDURAS
I found the following data (here in technical docs) for the T188 Transformer used in the TAB U73:
Haufe T188
Coil body EI 48/21 two chambers
Right chamber
515 turns 0.06 silk copper enamel wire
Copper foil
1030 turns 0.06 silk copper enamel wire
Copper foil
Insulation
Left chamber
same, wound in opposite directions
Do someone know what kind magnetic material was use for this EI 48 transformer laminations?
Was this a common FeSi magnetic material or special magnetic meterial?
Is possible found any supplier for or similar?
opacheco.
Pretty sure it’s the same lams as the V72 output transformer. And that was some kind of mumetal. Not that high nickel content as V72/76 input transformer but I think something like 40%. Maybe our member @flatresponse knows more as he analyzed original ones and sells a new version.
https://www.manfreddeppe.de/english-1/for-sale/
Murdock, Thanks for your response and comment.
In the Manfred Duppe website (your attached link) say:
"...one of the rare german sources of EI 48 mumetal core material still being produced in Germany we were able to develop a replica of the venerable T188...Grading has changed over time, but this material is something in between "Dynamoblech IV", the old (pre WWII) core material for transformers and a modern equivalent. I doubt, the old "german gun - material" does in fact produce the desired "sound"..."
Your comment look like very similar to the Manfred Duppe data there.
1-What will be the original T188 EI48 lams thickness?,
2-How we can to know the Mu-metal (nickel–iron soft ferromagnetic material) exactily alloy for this T188?, Do exist any kind of test for?
opacheco.
The Sowter V72 transformer data show a "100% Mumetal" core but I don´t know what this means?. I know Mumetal is a Nickel-Iron alloy and the percentage say the quantity of Nickel in there: Do the 100% Mumetal means a alloy 100% Nickel and 0% Iron ??
opacheco.
    32.4 KB
Stray thought:
..these places where you go to get your gold or silver checked for purity, don't they use something like a xray-spectrometer to get you exact percentages of a variety of metals with like three-digit precision? Could they perhaps as easily identify other metallurgic combinations..?
/Jakob E.
Mu-metal has different compositions but is Nickel, Iron, Molybdenum... described here
It's main characteristic is exceptionally high magnetic permeability but it is also a soft alloy.
Its main characteristic is exceptionally high magnetic permeability but it is also a soft alloy.
dump,
Nice info, thanks a lot.
What do you believe the Mumetal percent you say these german vintage kind of transformers was made? I am thinking to built some of them but I need this info (and another info) in order to do near as possible replicas.
opacheco
In one of my many conversations with Oliver Archut(I actually visited him once in Kansas) he told me the original lamination material used in many of the audio transformers originating from germany at the time was no longer in production, it changed to a lighter more efficient combination of materials favored by aerospace and defense industries for obvious reasons.
He insisted the older lamination material was superior for audio transformers but the size of the industry doesn't warrant producing the material...which makes sense whether anyone agrees with him or not about the performance of the material.
He said he had a collection of the older lamination material and could(and did) produce transformers but for a much higher price.
Oliver once sent me a T14 made from that material to evaluate...it was almost impossible to tell it apart from an original as far as appearance and it sounded identical to the original ones I have but then again so did a repro AKG sent me....so...maybe something with a hotter signal than a C28 like a limiter with a repro and an original T188 would be more revealing
He also insisted the T188 was the best interstage transformer ever made.
I would often counter his statements with the fact that I'm just trying to keep old gear operating reliably for my clients and that I had little time to AB the nuances of these esoteric materials, at which point he would offer to reproduce what I needed or rewind an old one.
I miss that guy and our conversations about life, audio and my home state of Kansas.
inkster,
Wow, that historíes are impressive. Did he ever mention to you why these transformers and it’s laminations are so superior?
opacheco
inkster,
opacheco
Again it was his opinion(of which he had many) and when I asked why he stated it was the particular alloys used in the laminations and that combination of metals was no longer being used in lams...the audio industry is not the driver of transformer production, either now or in the past.
It turns out that there is a specialist Mu Metal factory about 30 minutes drive from my home. I'll quiz them when I visit. I think they provide Stevens and Billington that are only about 15 minutes away.
It's mad, I'm about to buy a winder and they are all on my doorstep.
