There are many kinds of corrugated ribbons used in ribbon microphones (piston style etc.) The main difference I see in these ribbons both DIY and manufacturers is HOW the ribbon is made. Some have sharp perpendicular bends 'V' while others have more of a 'U' style bend. If anyone has any ideas or experience, please share? Which design seems to be more forging while installing it into a chassis truss? Do you know of any sonic differences? (The other style is of a piston style ribbon similar to Beyerdynamic microphones which have are a hybrid of flat surface as well as a couple corrugations on the ends. The flat surface supposedly extends the higher frequencies. Beyerdynamic uses a steel dies to print/press/shape the ribbon to obtain this unique design) Let's get a little Q & A and discussion going... the first image is a V shape the second image is a U shape the third is a hybrid between a flat and V.
