through-hole desoldering iron/tool/station recommendations in 2024?
You cannot use the Hakko FM-2024 without the parent station, which is considerably above your budget.
+1 When looking at desoldering stations you have to make sure it doesn't operate on "shop air". Shop air means you need a separate air compressor for the vacuum. You want a self contained vacuum.
I have used the Yihua 948 to recap my Trident 80 and have done about 2000 caps and a number of other components with it.
I've been pretty shocked, frankly, by how good it has been.
I purchased it sometime this year, so I reckon mine is also the upgraded/updated model.
Best of luck in your search!
