[quote author="Val_r"]I know how it sounds on the G9 since I've built one. But if you do not want problems, just go to transistors.
I always use PI filter with inductance, a battery of zener diodes in series with a PNP (MJE350) as a constant current generator, followed by 2 NPN in common base topology, using polypropylene caps and metal foil resistors, the result is amazing (250v output and you cannot even see the ripple on the 'scope!) pretty damn good.
Val
:razz:[/quote]
Unfortunately, I have absolutely no idea what you are talking about. :grin:
This really disappointing, the whole unavailability thing, as I have a project starting this weekend I hoped to use the G9 for. The voltage reg is the ONLY thing holding it back. :evil:
