GoGreenElectricsLTD
New member
- Joined
- Mar 17, 2013
- Messages
- 3
I have an existing TL783 based PSU which I intend to set at 90vdc output. The input source being a wind turbine rages from Zero vdc to 130vdc. There is a dump load controller with a large capacitor and this diverts much of the unwanted power to a large resistor bank. However the output when the dump load is in operation includes significant ripple produced by the dump load pulsing on-off-on-off at 4Hz. The purpose of the regulator is to stabilise the final output to a steady DC at maximum power.
I believe the TL783 PSU circuit could do this. But I would also need to connect a couple of 300w MOSFETS to handle the high level of power I think these will work
http://www.ebay.co.uk/itm/FQA11N90C-11N90C-TO-3P-N-Channel-300W-11A-900V-Power-Mosfet-FSC-/111007704892?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item19d893273c
Please could someone help me to design a small ADD-ON circuit to work as I have described.
Rob
Rob
