moamps
I have one anecdote about fuses and NTC resistor in power supply.
I received an huge audiophile amplifier from a friend at a service with a fault that the mains fuse burns out when it is turned on. I checked everything and set the rated fuse and everything worked ok. What actually happened? The amplifier has a soft start and a NTC resistor connected in series with the mains transformer to avoid large inrush currents. When the amplifier is turned on, the NTC limits the current with its high resistance but it starts to heat up and its resistance decreases so that the transformer gets full voltage in a short time. The NTC remains active in the circuit but is hot and its resistance is low. What was the friend actually doing?
He tested the audibility of silver and gold fuses (expensive) by turning on an amplifier with a standard fuse, the amplifier would work for a while, then he would turn off the amplifier, replace the ordinary fuse with an audiophile one, and turn on the amplifier again. And then the audiophile fuse would burn out, simply because the NTC resistor failed to cool down for that short time, increase the resistance, and decrease the inrush current.
It was a rather expensive experiment.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
From my experience the worst problem in general with power supplies is the short-term loss of mains voltage, which can cause a lot of damage especially on computers power supplies where ordinary fuses are not too helpful.
