bigugly
I've been thinking about this for a while. What I'd like to do is have a tube opamp that is modular so I can apply it in different ways. ie. pre-amp, virtual earth summing amp, ect.
These are my design goals:
high input Z - pretty easy with tubes
OLG - at least 60db
high CMRR - at least 50db
high PSRR - at least 50db
low THD+N - <0.1%
low output Z - less than 1k
here is what I've got so far.
This is by no means a working design. My problem comes when I think about how to add the buffer stage. The diff. pair is fairly easy and should get around 40db of gain with roughly 1mA of current thru it. Now comes my problem. If I take the inverted output and send it to say a SRPP stage to add more gain and get a lowish output Z then I invariably unbalance the diff stage because I am not loading the two halves the same. I've read that this will hurt my CMRR. I thought about adding a current mirror into the plates of the first stage but I couldn't find any good info for this relating to tubes. (there is alot of info for SS designs) This led me to draw the schem above. My problem with this setup is that I don't know if I have the top tube of the PP pair biased correctly. I did a lot of web surfing and read and re-read "Valve Amplifiers" by Jones but I'm not sure this current configuration will work. Any help would be appreciated.
One more thing. Once I have got this performing to my satisfaction I'm going to post the schem, BOM, PCB layout, and possibly have a run of boards made for myself and fellow forum members. Thanks in advance.
James
OLG - at least 60db
low THD+N - <0.1%
James
