pucho812
So I have 2 modules. They are the same module but for sake of discussion we will call them 81A and 81B. They fit into a 1081 8 unit vertical rack ams and are reissue units.
If I take module A or B and place them into slot 8 of the chassis they both work perfectly. If I place them into slot 5, one works and one does not. basically A&B work in slot 8 but only A works in slot 5.
As we know slot 8 powers both modules without issue, we can assume the slot is ok and we can assume that because both modules work in slot 8 that they are ok. In fact testing them with the AP yields expected results.
Both modules appear to measure the same physically including distance from the edge connectors.
In fact any measurement with a ruler comes out the same.
But slot 5, one module is working one is not.
The short answer is use the modules in the slots they are working in. No real harm or foul there.
But I am stumped as to why both modules will work in one slot without issue but only have one of the two working in another slot.
