Tone Bender Stomp Box - DIY
used the Aion FX Tonebender board and fabbed a retro box,
bought some Western Electric transistors from a guy on evilbay who matched them for the bender and it sounds great! Germanium, uses positive ground via a polarity flipper IC so you can power it from the same supply as your negative ground stuff,
Reply 12 and 16
https://www.diystompboxes.com/smfforum/index.php?topic=92104.0
I built a Si based one you need to read the thread for the final resistor values. In the thread there is a good youtube that you can hear how it sounds. I got the voltages close to the Ge version
https://www.diystompboxes.com/smfforum/index.php?topic=114210.msg1059856#msg1059856
