Toroid series and parallel secondaries
warpie
Ok, I'll be as quick as possible...  ;D
Can I get +/- 28Vdc from a 30VA 15V+15V 1A toroid, and if so how?
I connected the secondaries in series and I could only get a maximum of +/- 22Vdc.
I know is simple but couldn't find any info around  ::)
so, is it not recommended?
Even down to 500mA should be alright for my project.
How do I wire it?
secondaries wired in series, center tab not used.
Alternative solution
But in all cases, you'll need large caps and the xfmr will be stressed. Asking 500mA from a voltage doubler is asking 1Amp from the transformer. And single-wave rectification is hard on rectification transients and losses.
I wouldn't do it. Get a suitable xfmr.
    58.4 KB
thank you both for the diagrams  :)
So, it looks like getting another transformer is the best solution.
Will something like this do for my purpose (+/- 28V)?
I'm using the JLM Audio AC/DC PSU if it matters...
ENCAPSULAT TOROID 50VA 25V+25V 1A(RC)
http://www.rapidonline.com/productinfo.aspx?tier1=Electrical+%26+Power&tier2=Transformers&tier3=Toroidal&tier4=Encapsulated+toroidal+transformers&moduleno=72657
I hope to buy the right one this time  ::)
This one should give approximately +/- 35VDC at 700mAmp, which should be correct for regulating at +/-28. That's 7V across the regs. I don't know what the JLM regs are, but they should be fine with 7v drop.
thanks d enfer,
the jlm has two LM317s and one 377 so 7v drop shouldn't be a problem.
I'll try it.
thank you all for your help!
w.
