CJ
always wondered about the effect of core lacing, that is, a 3 x 3 lamination install vs a 5 x 5 or a 1 x 1,
so here is a graph showing what happens to the inductance as you install the lams in the coil differently,
there are some jumps in the graph as you will have uneven numbers of lams in say a 14 x 14 stack, as if you have 46 lams in a square stack, you will have 3 stacks of 14 plus 4 extra lams, which form a smaller group of lams, you know what i'm talkin about,
looks like once you get down to two stacks, the amount in each stack has little effect on the Henries,
one interesting discovery was that if you have a stack of 44 lams and two left over, the way you stack the last two can change the inductance, if you put them on opposite sides of the 44 lam stack, inductance goes up more than if they are both on one side of the bobbin, thus, if you have a choke with a gap, and you use two keeper lams, the keepers will add to the inductance if they are fitted going the opposite way of the E lams,
