Last winter I suddenly felt the need to find an use for a pair of extra Sowter 1:7 mic input trannies and decided to mod my CD player, an old ES-series Sony, just for fun. I don't remember the chips in it, but the DA-output surely was current output and symmetrical. I tried a couple of different I/V-resistor values, and surely it is easy to see that too much voltage will cause trouble. Anyhow I was able to get pretty clean 1V peak output with only 1:7 trannie, so staying under 100mV per phase was enough for that particular chip. Some 3rd harmonic can be seen. I only have simple j-fet buffers after the trannies. Noise is surely low enough.
I wish I had another unmodded player to compare the modded one to. But when it comes to the use of that particular player, enjoying music at home, the sound really seems to be good enough for me and the mod job was fun. I do tend to believe that the set of dubious capacitors and cheap OP amps didn't *improve* the sound from the chip, but I should have another player to do quick comparisons to really know. How ever, I did expect the sound to be a bit darker and less detailed in the treble with the transformer conversion, but did not hear that no matter how hard I tried. Quite the contrary. There is plenty of detail present. That particular trannie with those resistor values made a decent low pass filter, but I did add some passive filtering before the trannie, (I can not remember what, perhaps just shunt caps) and any conversion noise should not get through the system now. It certainly did without the extra filtering, so I would not blindly trust that any trannie is enough filtering.
Just my 2 cents.
-Jonte
