ProfPep
Active member
I'm doing some experimenting with Pultec type passive EG's.
The proper Iron I've got lives in the rack with it's associated devices.
Has anyone any suggestions for transformer simulating circuitry that I can use on my breadboarded circuits to get a reasonable, (I'm no way asking for perfect) response? Something I can put across the inputs and outputs to approximate the presence of a transformer, without the cost? I can ise load resistors, but that somehow seems to miss something.
For reference, I'm playing with an EQ design, but using reed relays to switch the caps, taps and resistors. What I intend to end up with is something that performs like a Pultec, has certain frequency differences, (like 50Hz rather than 60Hz - I'm in Europe!), and once that's sorted, can be controlled by a micro, to allow 'snapshot/recall'. I'd orginally thought of servo driven pots, but came to the conclusion that 0.5dB steps, on a selector would actually be better for repeatability and matching.
I have this control surface idea that has a shaft encoder with an integral push button for each band, rotating goes from cut to lift, press and rotate switches frequency bands . Q is on a separate control. Display is via LED's or an LCD panel, and the reeds keep the control system isolated from the audio.
I know, it will never fly..... but it should be fun finding out. I just don't want to have a pair of exotic ironmongery on the bench for the next 6 months, not doing a lot.
