Conviction
Hey all,
I found this little cutie yesterday. At first I thought it was a tube preamp, fooled by the looks. This seems to be some kind of a prototype build and I'm quite sure it's from the former NEFA factory here in Sweden, where Philips built a lot of broadcast equipment back in 50's and 60's (remember the Philips-NEFA thread? There's lots of similarities). I don't think this one ever was in production or even considered. Hard to tell. It was, however, tested 5th of may 1969, so I guess someone used it now and then.
The unit was designed so that it could run on a 6.3V battery (5x1.25 battery pack) or mains. Unfortunately the mains circuit seems faulty, but I guess even a wall wart could do the job (if I'm not able to fix it).
The transformers are all Jörgen Schou, which is nice. It even sports a Daven attentuator (see pics).
The transistors are OC603's, OC604's and OD603's.
I got very little knowledge in early transistor technique and am a little curious about the performance of these (germanium) transistors.
Do you think I should put it to use or put it on, well... display?
Here's some pics (without it's brown tolex cab):
... The actual preamp sits inside an internal shielded housing (here without the filter caps, gotta change those asap):
Olle
Olle
