Triad HS-3 and other odd Triads
Quayhog
Bay Area California
Do any of the group here have DCR readings for a Triad HS-3.  I believe I may have an industrial equivalent with a part number P-90210.    It's heavy and it physically equals the size listed in the catalog.
Another question about Triad transformers I have a few 600:600 transformers that have an industrial number.  It's from old telephony equipment and it's listed with 5000 cps.  The size and weight are the same as the HS-56.  Do Triad transformers exceed routinely exceed published data.  I'd like to use these if they atleast go to 12k.  Without an oscilloscope how can you tell what you have?
that is just a military spec, it will be good for 20K and more if it is a 600:600
no info on the HS-3, working on it, pri ohms should be around 10to 40 depending on how many coils you measure,
Thanks.  I collecting parts for a Pultec build I can test the 600:600 in circuit and compare with an original that's called for in the schematic.  I'm hoping for the best, expecting the worst.
We put a scope on the 600:600 industrial Triad and it's flat to about 19k.
I'm still trying to locate the specs for the P-90210.  The DCR is real similar to the readings I get when I measured the Triad B6299 inputs that came from old Ampex equipment.
When you google it it has the unfortunate number in common with Beverly Hills zip code.
